Old 09-26-2008, 07:22 AM
dirtdriver11 dirtdriver11 is offline
98 cavalier headlights
Just got a 98 Cavalier, the daytime running lights work, the headlights work on dim, but only one headlight works on bright. any suggestions?
Old 09-26-2008, 09:39 AM
muff34 muff34 is offline
Re: 98 cavalier headlights
burnt out head light or the infamous wiring problem which occurs in wiring harness up front
Life Is A Highway ,Enjoy The Ride
Old 09-26-2008, 11:13 PM
replaced headlight, fuse is also good. what exactly is a the wiring problem?
Old 09-27-2008, 03:49 PM
bad connections/splices in the wiring harness up front between headlights. strip the duct tape type covering off harness looking for the splices uncover splice ,it is likely corroded. High beam is pink wire if I remember correctly
Old 09-27-2008, 07:21 PM
thanks, i'll check that out.
