Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-25-2008, 09:26 PM
98CrownVicKid 98CrownVicKid is offline
Changed battery, now dome light flashes and clicks
Well, my battery light was coming on so I checked the "meter" on my old battery and it said it was no good. So I went to Napa, bought a new battery and had it checked. After I installed it my dome light flashes for about 3 minutes everytime I start the car and if I shut the car off and take the key out within that time, it still flashes. Also, it's making a ticking noise almost identical to the directionals. No clue why it's doing this. Do I need to go to the dealer to have the computer reset or what?
When a man becomes a fireman his greatest act of bravery has been accomplished. What he does after that is all in the line of work. ~Edward F. Croker
All men are created equal, then a few become firemen. ~Unknown
Old 09-26-2008, 12:03 AM
reekor reekor is offline
Re: Changed battery, now dome light flashes and clicks
Battery lights mostly come on due to bad alternators and not batteries. Did the new battery die yet?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-29-2008, 08:28 AM
I ran a scan for codes and nothing came up. New battery is still fine but the light still comes on at random.
Old 09-29-2008, 11:55 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The clicking noise you describe sounds like the lighting control module is the problem. They are not cheap. So you need to find out before replacement. ou might want to find someone that has a high end scan tool that can read the various modules on the car. Then you can be sure where the problem lies. These are usually found at the Dealer or a real good shop in your area. Ask around. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-30-2008, 02:48 AM
tarikeonu tarikeonu is offline
hello from ny, based on ur problem i had a similar problem as u know black box or light control box wich is under the dash bord it has three plug connect to black box either one could be loose or burned inside u can changed one at a time.u get it from junk yard they have it mine like headlights used to goes off and on click click also noise too u can do it ur self make sure u match the wire hopefully it will work.
