Old 09-25-2008, 12:41 AM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Boost Hesitation
When I first bought my car, one of the vaccum lines came off of the boost solenoid causing me to over boost and then get fuel cut. Well, once I reattached it, it ran great. Now, it is doing the same thing agian and the line is still connected. I am not sure if it is over-boosting or what but it feels like the same thing. And here is the catch, not always does it do this. Most of the time yes, but not always. There is very noticable jerking in the power when I am WOT and really want to get this fixed. Any ideas?
Old 09-25-2008, 06:54 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Boost Hesitation
Plugs
Old 09-25-2008, 10:29 AM
VR43000GT's Avatar
^^Are you pretty sure that's what it is? Spark blowout then?
Old 09-26-2008, 11:44 AM
Stealthee's Avatar
Definitely sounds ignition related to me.
Old 10-01-2008, 08:09 PM
701-3000GT's Avatar
701-3000GT 701-3000GT is offline
Yeah, im having the same issue
i was told to regap the plugs also
Old 10-02-2008, 08:57 PM
701-3000GT's Avatar
My problem turned out to be my alternator, it started exactly with your symptoms and gradually got worse
the correct voltage wasnt getting to to plugs (copper tip:requiring a little more power than the other metal tips) causing the spark to be too weak for boost.
by no means im i saying its your alternator, but just a worst-case scenerio and something to be aware of.
Old 10-02-2008, 11:13 PM
VR43000GT's Avatar
^^This is actually kind of scary because mine, like yours, just went away all the sudden. If I start having the adverse affects that you experieced after this I will be sure to look into it.
Old 10-02-2008, 11:23 PM
701-3000GT's Avatar
good plan, just watch for your warning lights on your cluster. if some come on randomly and dimly, theres your sign. hahah.
its not too terrible of a cost though, mine is ending up to be around $300 with labor included.
so all in all, worse things could happen
Old 10-02-2008, 11:27 PM
VR43000GT's Avatar
Lol, I hope it doesn't happen. My ABS light came on once about a week ago but it wasn't dim and hasn't returned since. If it needs a new alternator I'll replace it myself but even still, I don't want to do it if I don't have to lol.
Old 10-03-2008, 12:56 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Ehh, it's not that bad. You can do it in about 30 min.
Old 10-03-2008, 11:59 AM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Wow it sounds like it may be the same problem as 701 had.
On a side note, you said your ABS light came on? Did the ABS still work that you know of? I ask because you can disable them until the next time you turn on the car by turning a corner and hitting the brakes fairly hard...all while yanking the e-brake for a second just so the back end slides a tiny bit. Dont ask me how I know this...it was kind of a fluke thing that I replicated just to see if my theory was correct. Im guessing that it wouldnt work like that with AWD locking the e-brake, but just a random fact for you FWD guys.
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 10-03-2008, 12:50 PM
VR43000GT's Avatar
No, I have not tried that and I'm not sure I want to know how you know that either.
Old 10-03-2008, 05:26 PM
Polygon's Avatar
The Red Baron
So, you're calling it a science experiment? Sure, it's your story. You tell it how you want.
