| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Malfunctioning fp gauge? or not
so, i got into my car, and the fuel pressure gauge went to 0, then shot to 100psi(the limit of the gauge)....car runs fine...does this mean its definately a gauge malfunction?
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges |
Re: Malfunctioning fp gauge? or not
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
deffinately sounds like a loose ground.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
ok i will look, thanks guys!
Damn...got that fixed...now i got another problem...
The owner b4 me installed an apexi turbo timer. Just 2day it turned off. So i went to playing with it and traced the wire, it worked again for about 2 seconds, turned off, hasnt worked since... I traced the only cord that comes out of it, it eventually goes to a little black piece and comes out as a red wire and black wire. this then ends at a small black module. So i open up the ground wire, and ran it straight to a ground. I could hear the module clicking on and off, but the unit itself wouldnt come on, and its fairly new, i havent hit it or done anything else to it that would cause it to malfunction... any ideas?
is this just the power source? if it is then just pick a new + 12v wire that isn't shorted.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
i traced the wire of the turbo timer, turns out it had come unplugged from the ignition box under the steering column lol...
dont i feel stupid but i do feel better haha thanks anyways, oh and fp gauge is still messing up, but if i was running that much fp would i know it? i mean 100 psi...whens its supposed to be less than 50 at idle...thats what the gauge reads.. and also, a guy today told me that even 47 was too high(where i have it set) is it? with my mods? i mean the car doesnt sputter or spark knock or anything, all the way through the power band...so something must be right
ok awesome...ill tinker with it when i get my air/fuel gauge...see if i can keep it on a prime setting...is this the best way to do that without having a a/f controller? just sort of gauge it by the meter..?
If you're getting a non-wideband gauge, send it back as soon as it hits your doorstep.
With a wideband setup, you can get your fuel trims in line using some sort of management device and a logging device. Trying to "guess at it" will leave you pissing in the wind. Oh wait, did I just help you?
Kris 2012 Genesis Coupe 2.0t |
lol, yeah, i just wanna stay outta the red is all, make sure im not running rich at anytime...tweak it from there?
i am planning on getting some things from apexi when i get it tuned in a few weeks...guess i can just wait, im not having any problems or anything...my engine is still in one piece lol
lol yeah, i just wanna make sure i stay out of the red
wanna monitor it better, but i mean im not having any problems, and my engine is still in one piece lol umm, im planning on getting it tuned, and when i do im buying a air/fuel controller from apexi...guess i should just wait before i go tinkering, since im not really having any probs, thanks guys!
Wideband and a logger...wait to get the cooler toys till you can be sure your motor will not be at risk.
gotcha, thanks!
