Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 09-24-2008, 05:55 PM
slimm22 slimm22 is offline
Question 98 Yukon 5.7 help
I have a 98 yukon (4x4) 5.7. I have two problems with it right now. (1) when I pull off and come to a stop, it has a bump to it, it sounds like it is coming from the back of the truck. (2) when I turn the key to the run position, the fuel hand vibrates real bad back n forth, and the tank has a whine as well as a heavy vibation to it. you can feel it through the driver side seat. it even does it when the truck is running. please help if possible. thanks. if it is the rear end is there another truck i can take the parts from.
Old 09-25-2008, 04:06 PM
rican4lfe rican4lfe is offline
Re: 98 Yukon 5.7 help
I have a 97 2dr yukon..... mine started with the hitting sound comming from the back and all I did was to replace the diff oil and the sound have been no more
Old 09-25-2008, 09:29 PM
Adventurer_96's Avatar
Adventurer_96 Adventurer_96 is offline
I just replaced my fuel pump, sounds like yours is dying. Expensive but necessary. Check into getting your fuel quantity sending unit replaced at the same time.
Check six.
Old 09-26-2008, 11:18 AM
how much time do you have before they go out, from where it is now. I need it to hold up for 2 to 3 more weeks.
Old 09-26-2008, 11:21 AM
and I'm gonna change the diff (oil) in the rear this weekend
Old 09-26-2008, 09:22 PM
damdash damdash is offline
mine has been doing the same thing with the needle jumping for the past year and i still haven't had to replace the filter although i did replace it about 2 years before it started jumping. I would lean more towards the fuel quantity sending unit.
Old 09-29-2008, 01:58 AM
Hard to say. I was lucky, mine didn't die on a long trip across the country, but I saw it happening a month or so beforehand.
It sounds like both the pump and sending unit are bad, since there's a strong whining.
Check six.
