Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-24-2008, 01:16 PM
DuneBoy DuneBoy is offline
Cool odometer
the odometer on my 99 expedition goes on and off. doesn't appear to be any pattern, sometimes it just gets dimmer
Old 09-30-2008, 11:53 PM
yotermanic yotermanic is offline
Re: odometer
I know I'm late getting to this post, but I've actually seen this one before, it's usually the dimmer switch next to the headlight switch...but it's pretty pricey so unless I could get a good reading with an ohm-meter, I'd probably live with it (or put in my known good one in my toolbox and see if it stops...yes the professionals cheat every now and again!) Good luck with it.
Old 10-02-2008, 07:25 AM
Thumbs up Re: odometer
thanks, I will take a look at the switch.
Old 12-12-2008, 11:56 PM
mrfixitmi mrfixitmi is offline
Re: odometer
I had the same problem with my 1999 Expedition especially in humid/damp weather. The bad news is that you have to remove the gage cluster, the good news is that it may be due to a cold solder joint, that takes $.05 of solder. I fixed mine over 130,000 miles ago, and have had no repeat of the failure.
You may want to look for a cracked/corroded ground pin on the backside of the printed circuit board (directly behind the odometer read out). There is a great link that explains the procedure:
Hopefully this link will atttach.
http://www.f150online.com/forums/ele...-repair-2.html
Good Luck
Old 03-09-2009, 04:06 PM
janco janco is offline
Smile Re: odometer
I fixed my odometer over the weekend it took about 1 1/2 hours cold solder joint was the problem.
I stole $600 from the dealer.
Thanks
