Old 09-23-2008, 02:48 PM
diejediknight diejediknight is offline
Angry 1996 honda accord upper radiator hose collapsing
..ok..replaced the radiator(hoses too) because it was cracked..no big deal.so i check the coolant a couple days later and noticed the upper hose keeps collapsing.its the 2.2 engine(no vtec)auto trans...got me stumped.never heard of a thermostst causing this condition.no luck under the forums search either...any help is much appreciated.....Matt
Old 09-23-2008, 03:06 PM
KiwiBacon KiwiBacon is offline
Re: 1996 honda accord upper radiator hose collapsing
Did you bleed the cooling system around the thermostat afterwards?
I did the thermostat on a 96 accord once, there was a bleed nipple (similar to a brake caliper bleed nipple) which was necessary to get the air out.
Old 09-23-2008, 03:13 PM
i havent replaced the thermostat yet. i did not see a bleed valve at the housing when i did the hoses.im gonna replace the thermostat tonight and make sure that i get the system bled correctly.thnx for the advice....Matt
Old 09-25-2008, 11:38 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
There is a vacuum release valve (a 'drop valve') in your radiator cap which is likely stuck closed. Free up the valve or replace the radiator cap and you should be okay.
Old 09-30-2008, 06:04 PM
yuppers ...the new radiator was bad..thanx for the help guys....Matt
