Old 09-23-2008, 01:00 PM
jglenn jglenn is offline
need help on 1989 Cherokee Laredo
how do the front axle lock on a 1989 cherokee laredo it don have vacuum
control system on it do the transfer case lock the front axle if it do how do
the axle lock
Old 09-23-2008, 09:55 PM
gatoratoy227 gatoratoy227 is offline
Re: need help on 1989 Cherokee Laredo
atuo lock hubs or vaccum actuator on the front axle
if it has the vaccum actuator it will look like a canister on the axle with a hose or 2 connected to it
NO! ,we can't stop here, this is bat country. Raoul Duke
Old 09-24-2008, 11:51 AM
it don have no vaccum actuator on the front axle so it atuo lock hubs ok how do atuo lock hubs work
Old 10-12-2008, 07:17 AM
trailmaker73 trailmaker73 is offline
Send a message via Yahoo to trailmaker73
i don't know if this will help or not on my 89 jeep i have a turn knob (don't know the name) under the dash by the 4x4 handle that i turn after i put it into 4 high. do you have somethinglike that?
tread lightly!!
Old 10-12-2008, 09:24 AM
Saudade's Avatar
Saudade Saudade is offline
The factory setup uses a vacuum control system. There's a vacuum actuator io the top of the axle tube and a shifter fork housing.
If these are not there, then a previous owner swapped out your front axle. In that case the axle is always locked regardless of 2wd, 4wd or even neutral. The TC only engages the front drive shaft. There are no locking hubs unless, once again, a previous owner modified your setup.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
