Old 09-23-2008, 12:56 PM
Mr. Cynical's Avatar
Mr. Cynical Mr. Cynical is offline
Send a message via AIM to Mr. Cynical Send a message via Yahoo to Mr. Cynical
Intermittent Radio - Back Speakers
So, the radio comes and goes on my 99 GTP, factory delco still in place.
The long and short of it: If it's a warm, dry day, they work. As soon as it cools off in the evening, no speakers in the rear. The fronts work just fine.
Should I be looking at wiring, or has anyone run into this with the factory unit itself?
Your Pal,
Mr. C
Goethe once said, "A useless life is an early death."
In Goethe's terms, many of us are already dead.
Old 09-24-2008, 12:20 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Intermittent Radio - Back Speakers
Sounds like another speaker issue.
Do you have the bose system?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-24-2008, 12:32 AM
doctorhrdware doctorhrdware is offline
Also could be cold solder joints in the radio it self, which I think is more likely. The reasoning behind this is due to the fact is that it does work when the temperature is warm, but as soon it cools off the speakers quit working. It is also possible that the speakers have cold solder joints and this would also have the same effect with the temperature changes. Or if the system has a separate amp for the rear speakers that could also be the problem.
