Integra '94
I have an Integra LS '94. The brake fluid went low so I bought Preston Synthetic Brake Fluid DOT 4 (compatible with DOT 3). Eversince I poured this fluid in, whenever I step on my brake, it Brake and Stop HOWEVER after couple seconds the brake paddle slowly press in by itself and causes the car to move by itself too. Hope you guys can give me advises. Thanks
Re: Integra '94
you need to bleed your brakes,when the fluid went so low(why)you got air in your brake line. you need someone to pump and hold brake peddle to get the air out. Brake fluid will take the paint off anything be careful and next time check those fluids but you should never mix any. hope this helps,try not to drive to much until you remove the air or your master cylinder could go out. good luck!
