Go Back   Automotive Forums Car Chat > Suzuki > Sidekick
Old 09-23-2008, 11:21 AM
Oxxon Oxxon is offline
Valve Cover Removal
My girlfriend's 94 16v SideKick 4x4 seems to be leaking oil from the valve cover. I can only see 6 bolts on the cover. Am I correct? Aside from what I have to remove that is above the valve cover is there any thing else I have to remove/loosen to take the cover off?
Thanks in advance...
Old 10-06-2008, 08:49 AM
kick3 kick3 is offline
Re: Valve Cover Removal
IIRC, that is all you need to do other than remove the stuff on top of it. Are you going to adj. the valves while you're there?
kick3
Old 09-01-2009, 12:26 PM
MAXIMUS_PRICO MAXIMUS_PRICO is offline
make sure is not the distributor O-rings sidekicks and trackers are known for this defect goggle it
