Old 09-23-2008, 01:34 AM
KyMDLR's Avatar
KyMDLR KyMDLR is offline
PCM's
I am curious. What are the advantages for having an aftermarket PCM?
My 05' GP is STOCK performance wise, and I am looking for some add-ons to make my car have some more power!
After purchasing a new PCM is it simple plug and play or is ther alot of work involved with installation? Any suggestions/input is appreciated!
Old 09-23-2008, 08:35 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: PCM's
It would help to post what model '05 or which engine.
Re-programmed PCMs are plug and play. A crank variation learn is recommended whenever PCM modules are replaced but not mandatory. Also, premium gas will be required to get full advantage of the programming changes.
Timeslip 08/12/06
AF Community Guidelines
Old 09-23-2008, 07:48 PM
KyMDLR's Avatar
Re: PCM's
My error. 05' GP Gt. no supercharger.
Old 09-25-2008, 07:36 PM
BNaylor's Avatar
Re: PCM's
See link below which covers the DHP PCM.
Click here
Timeslip 08/12/06
Old 10-04-2008, 02:00 AM
birar birar is offline
Re: PCM's
u have 2 have atleast hav a 3.4 pully a u bend delete some form of an aftermarket intake but yeah on my 98 gtp it was plug in play with the pcm installed it connected the battery and it fired rite up with no codes sometimes u have problems with them throwing codes theres a certain learn process for it i didnt hav to do that cuz mine was fine good luck but u need those mods for ur car to perform otherwise it will run like shit with that pcm
Old 10-04-2008, 09:59 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: PCM's
Originally Posted by birar
u have 2 have atleast hav a 3.4 pully a u bend delete some form of an aftermarket intake ....
No you don't, its just recommended by the PCM manufacturer.
The only thing you HAVE to di is run Premium 91 or higher.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-06-2008, 06:15 PM
KyMDLR's Avatar
Re: PCM's
I didnt know about the Premium gas. 87 Gas now is already burning me lol. what happens if u run 87?
Old 10-06-2008, 06:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: PCM's
It would be rather difficult to put a 3.4 pulley on an engine with "no supercharger"!
Old 10-06-2008, 06:28 PM
Highbeamz Highbeamz is offline
Re: PCM's
Well the stock PCM is specifically designed for 87 octane, it's tuned to run on it. If you swap to an aftermarket PCM, they are tuned more aggressively, especially in the spark mapping and knock retard departments. They are designed to run off 91 octane to combat the knock you are likely to see off that setup. If you run 87 octane, you'll likely be fine...for a while that is, because I bet your knock retard will be rediculously high. With the hp you will gain off the PCM, you will lose if you run 87 octane, plus the possibility of piston damage due to knock.
I would suggest if you get it, keep your original PCM so if you can't keep up with the price of premium (which isn't THAT bad), then swap back to factory. That's just what I would do. Of course since I drive a GTP I already pay for the premium, so no loss to me when I run an aftermarket PCM :P
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 10-06-2008, 06:48 PM
BNaylor's Avatar
Re: PCM's
Running 91 or better octane premium gas on a NA SII/III 3800 engine is for maximum hp across the complete power band. You can get by with 87 octane regular octane. Just don't WOT - pedal to the metal too frequently because even a NA engine can get knock retard (KR) which is not good. The basic Stage 1 PCM modules have the WOT timing tables increased by a range of 1-4 degrees depending on the company that programs them so it makes more sense to use premium gas versus regular.
Timeslip 08/12/06
