Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-23-2008, 12:07 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Wheelspin?
Hey I have a question about wheelspin. What are some ways to reduce it? I put on all new tires today with the best traction I could find.
I was just wondering from your experiences if there was anything else you could do...
I get it worst when I boost too high in low gears, and id lik eto try to reduce the amount. Thanks!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 09-23-2008, 12:44 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Wheelspin?
Stiffer rear springs, stiffter front shocks, wider tires, LSD, upgrade tranny to 3.55 gears. Being fwd there is you can do to eliminate all wheel spin. You can upgrade the car some to help not spin as much but learning how to handle the power in lower gears will help out most. Either get some kind of boost controller that changes with each gear or stay off the gas a litte in lower gears to control the spinning.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-23-2008, 08:25 AM
steviek's Avatar
steviek steviek is offline
Re: Wheelspin?
also letting out some air from the tires. Will kill your mileage though
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-23-2008, 02:55 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Wheelspin?
Everything said above it right. I personally use the air from front tires. If you're driving to a track to do this, make sure you bring a mini pump or whatever for the ride back. Probably the easiest thing to do. Works quite a bit on mine and I've got a CF hood, stock shocks, no A/C and everything stripped down as much as possible.
Also adding weight to the front works, like a heavy front lip. Are you using rims with low profiles? Those tend to spin more from what I've seen.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-23-2008, 08:45 PM
Re: Wheelspin?
Wow great answers =)
Ok, lemme fill all of you in, ill tell you as much as I know.
I know,that when my best friend rides with me(weighs about 200) I get wheelspin BAD and much worse power...by myself, it sails like no tomarrow.
I have a boost controller,but not an adaptive one like your talking about, but I like the sound of it, no anyone who makes them? I assume you mean it would have a preset boost limit in each gear?
I JUST bought brand spankin new kuhmo tires witht he best tread, so ive got tires covered, they work a bit better than the ones I had, as far as eliminating wheelspin.
I feel like im leaving something out...
anyways, if I think ofit, ill let you all know!
Thanks so much!
Old 09-23-2008, 08:48 PM
Re: Wheelspin?
Oh yeah...no im not, ive got stock rims...
and I am planning on getting a front lip here soon, so that should help more than not having one at all, ill try and get the heaviest one I can find I guess lol
No of any websites that sell a good variety of front lips for the eclipse?
Old 09-23-2008, 08:49 PM
Re: Wheelspin?
Oh and one more thing, anyone know where I could find the lsd for my 97' eclipse rs? And the gears the other guy was talking about? I searched, couldnt find em...
And whats the differnece between the lsd I have and the one I need? I mean like the technical difference..?
Old 09-23-2008, 08:54 PM
steviek's Avatar
Re: Wheelspin?
simply put
limited slip differentials take power away from the wheels that are spinning so that they get an opportunity to gain traction simple as that but actually quite complex
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-23-2008, 10:37 PM
Re: Wheelspin?
ok, so how do you go about installing them, simply put?
Old 09-23-2008, 11:46 PM
Holset powered 420a
Re: Wheelspin?
You install them inside the tranny.
a lot fo 2gnts change to neon gears in their tranny. The neon trannies have a slightly higher gearing which will help keep spin down. Search 3.55 gears on 2GNT and you will find plenty of info. Keep in mind that even doing all of these mods are not going to help out much if you cant drive. You are always going to get some spin in a fwd you just have to control it with the gas peddle. A good driver and some of these mods and you should be launching pretty well off the line.
Im thinking that the apexi boost controller may be able to adjust per gear. Could be wrong but I think I heard that somewhere. You could always use a switch that will cut the boost controller on/off so you can run say 12psi off the line but flip the switch and run 20psi after second gear or so. It would also allow you to run lower boost daily to help keep spin down if you happen to step on the gas.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-24-2008, 03:55 AM
Re: Wheelspin?
Niiiice
Well the boost controller I have has a button to push, and has 2 presets, low boost and high boost, around town i keep it on about 15 psi, and I get a little spin if im in the car by myself, and I im capable of 19 so...im guessing with the right mods, I can eventually be able to handle the 19 MAYBE if I can perfect my driving a little more...Like I say, my current driving skills allow me to handle 15 or so without spinning...so I suppose I need to go to the track a little more often, get some more experience...
Ok I think im gonna buy a kaaz lsd in few weeks...(2 paychecks) lol...umm if I buy the lsd, is that all I have to buy in order to have it installed at a shop? or does this mod require that I buy more? Basically, an anyone provide a list of the parts ill need to do the swap, given I was taking it to a professional shop?
Thanks!
Old 09-24-2008, 08:58 AM
Holset powered 420a
Re: Wheelspin?
It should just drop right in. You should be able to do it yourself if you want to take out the tranny and open in up.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-24-2008, 01:06 PM
Re: Wheelspin?
Ok so it just replaces, thats all...good to know... thanks a lot guys, when I get around to buying one, ill let you all know how it works out...
Thanks!
Old 09-27-2008, 07:56 PM
Re: Wheelspin?
when yuo say let the air out...how much? how much should i have in em i mean...
and just on the front ones?
Old 09-27-2008, 08:18 PM
steviek's Avatar
Re: Wheelspin?
yes just the front ones. And it really depends the more air you let out to a point the better traction you get but your economy suffers.
My best advice would be to incrementally decrease the air a couple psi at a time and go from there see what works best. If you can eliminate the spin with only letting out a few psi thats great then you're done. If not well at some point you will have to say ok thats enough.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
