Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-22-2008, 10:00 PM
mike561 mike561 is offline
Code 14?
Did the paper clip trick, and counted the check engine light blinks and determined its a code 14 (oxygen sensor and throttle position sensor) should i just replace both? also whats involved in doing the throttle pos sensor??? the past few weeks the check engine light has been comming on when im stopped then will go back out after about 2 minutes.
2006 Chevy Cobalt LS
Old 09-22-2008, 11:20 PM
inafogg inafogg is offline
Re: Code 14?
whats the engine???vin code # i believe its the 8 # on vin
Old 09-22-2008, 11:44 PM
Re: Code 14?
305 5.0, with the 4bbl carb, mostly everyone here knows my engine specs cept a few
Old 09-23-2008, 05:39 AM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: Code 14?
Yup i'd replace both. Having the same exact car as you i'm willing to bet your TPS does need to be replaced. Mine did. I think you mentioned that your car idles wierd a while back and the TPS should do i think. I had mine replaced and now idles just fine.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 09-23-2008, 07:31 AM
Re: Code 14?
yeah i think ill just replace both, i know you had yours done recently, i just wanna know whats involved in replacing the TPS and how hard it is.
Old 09-23-2008, 12:38 PM
Re: Code 14?
thats why i asked Mike im showing code 14 as temp.circuit to high
if you can whats the vin # are we talking about the 88 or the 83
Old 09-23-2008, 05:43 PM
Re: Code 14?
My 83, i just replaced the o2 sensor, no check engine lights yet, i also connected it to my work's code scanner and it came back that it was a code 13 instead, said something about an open or shorted circut in the o2 sensor (i ran the code scanner after i put in the new sensor) diddnt say anything about a tp sensor tho
Old 09-23-2008, 07:54 PM
bhw33191's Avatar
Re: Code 14?
Yeah mine didn't mention anything about the TPS in a code either. But when it was in the shop the guy said it needed to be replaced.
Old 09-23-2008, 11:07 PM
Re: Code 14?
Ill probably end up doing that soon either way too
