Old 09-22-2008, 07:21 PM
Cannon84 Cannon84 is offline
Angry Day time running lights don't work
I've noticed recently that my day time running lights do not work. I've checked all the fuses and they are good. I looked in my manual and couldn't find anything that would help me. Now I'm turning to the forum for a possible solution. Any and all help will be highly appreciated.
Thanks in advance for any help
Cannon84
Old 09-22-2008, 09:09 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Day time running lights don't work
Hmmmm,
Mine havn't worked since the day I bought the car....... On Purpose
But could you explain what they are doing? Not on at all? Low beams on constantly?
Check the sensor in the middle of your dash. There isn't a bunch of junk up there is there?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-22-2008, 09:16 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Have they ever worked? Like Tim I disabled mine. Cuts down on the "on" time for my expensive Sylania Silver Stars. Moreover, I prefer to manually have control over my headlights.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 09-23-2008, 12:05 AM
Sorry about not giving all the information. The lights don't come on automactically as they did when the vehicle was new. I prefer to have manual operations over them I just wanted to know the reason they didn't work just in case I decided to fix the problem. One thing that I did pick up from this post is that I do need to change to a higher intensity bulb. I replaced both headlight assemblies about a year ago but the day time running lights had stop working well before then.
Any suggestions on the best bulbs for replacement? The $14 or so bulbs from my local Autozone is not bright enough at night.
Thanks,
Cannon84
2000 Grand Prix GT
99,435 miles
Old 09-23-2008, 08:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Although the DRL fuse appears good did you check for 12 volts at the fuse socket? If 12 volts is there then you probably have a defective DRL module. It controls the auto headlamp system in addition to the daytime running lights. If 12 volts is missing then the problem is further back possibly the ignition switch or wiring fault.
Timeslip 08/12/06
AF Community Guidelines
Old 10-03-2008, 05:46 PM
f4istunter f4istunter is offline
Hey
I learned of this a while back, seems none of you know of this
You can disable day time running lights manual by unpluging a connector
Open the drivers door , look on the dash that is covered by the door when its closed, there will be a small access panel, open it
there will be a blue plug visable , PLUG IT IN if it is unplugged to have the running lights. vice versa to disable them..
Cheers
2001 GP GT
1997 GP GT (Parts Car)
