Speaker Help
The right rear deck speaker all of a sudden stopped playing. It is still plugged in but no sound comming out. Suggestions of what to do would really help.
Re: Speaker Help
do u have a stock or aftermarket head unit/radio
Re: Speaker Help
Get a digital volt meter, and measure the speaker impedance. You should get a reading around 4 ohms, If you do not measure any resistance the speaker voice coil is open. That is why you are not getting any sounds from that speaker.
Re: Speaker Help
i know this may sound obvious but check the fader and make sure its not set to just the front of the car. also if there has been any wiring done to the head unit or speakers the wires may have come undone.
Re: Speaker Help
It Is a stock unit, the fader is correct ( not an idiot ), , wires are connected from what im able to view, I dont think theres a problem with the speaker itself probably something else
Re: Speaker Help
Use a DVOM, set it to measure AC Voltage and then fade and balence the sound to only come out the right rear. Then probe with the DVOM each side of the speaker + and - connection with it plugged in. You should read some AC voltage. If nothing, start looking into a wiring problem or a problem with the head unit. Do you have a bose system by chance?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: Speaker Help
Yes i do have the bose system and thanks ill try that
Re: Speaker Help
The first thing I would try is plugging in a known good speaker. GM factory speakers start intermittently failing before suddenly quitting altogether. If another speaker doesn't help. you probably have a bad right channel in the bose amp.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: Speaker Help
I was just going to mention the amp.
