Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 09-22-2008, 04:28 PM
kz94b5 kz94b5 is offline
'94 pontiac transport plug wire protector
I need to tighten my front valve cover but cannot access two of the bolts as they are blocked by the wire guide for the front plugs. How do I remove the wire guide?? 1994 pontiac transport
Old 09-24-2008, 11:19 PM
Jeffrv's Avatar
Jeffrv Jeffrv is offline
Re: '94 pontiac transport plug wire protector
I presume you have the 3.8 engine, lift it straight up it is in guides molded into the valve cover
Jeff
Old 09-25-2008, 09:34 AM
LMP's Avatar
LMP LMP is offline
Jeff
?!? ...Thanks Jeff....I'm now going to reroute the new wires I had installed last year..or was it the year before...anyway.....and discard the stubs that were left in the wire holder....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 10-03-2008, 08:52 AM
jeffrv--thx response yes it's a 3.8--the 'dogbone'? will not allow the cover to be lifted--can the dogbone be removed to allow the cover removal w/o the engine relocating itself?? (i'm guessingthe dogbone is to keep the engine from rocking only, not really supporting any weight)
Old 10-05-2008, 12:01 AM
Jeffrv's Avatar
Sorry, forgot to mention that, the dog bone can be removed without the engine tipping. I loosened the bolt on the engine bracket, and removed the bolt on the upper rad support to swing the dog bon out of the way
Jeff
