Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-22-2008, 01:52 PM   #1
scoopy03
Unhappy 92 notchback how to roll up power windows
I just this car from a friend. It is just the complete body minus engine and transmission in it currently. The problem I am is having is how to roll up the power windows with nothing to put the terminal onto. There is no solenoid on the frame and no starter. I am fairly mechanically sound but this is just something I never done yet. I tried to hot the wire from the door panel but no avail.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
scoopy03 is offline   Reply With Quote
Old 09-23-2008, 11:38 AM   #2
scoopy03
Re: 92 notchback how to roll up power windows
anybody????
Old 09-23-2008, 07:11 PM   #3
rhandwor
Check for a spare spot in the fuse box where you can install a fuse and install a wire. You can always use a round type connector put it on the positive cable with another nut. Just use an inline fuse holder. Normally they have blanks in the main relay center for towing hook ups.
rhandwor is offline   Reply With Quote
Old 09-24-2008, 04:23 PM   #4
scoopy03
well i found the solenoid buried in the trunk after i tried the wire from the fusebox give the car a jump start and now windows are up
