Old 09-22-2008, 12:13 PM
beachrog beachrog is offline
Dash cracks
My dash cracked in the middle where the screw goes into whatever mount is under there. Now it bounces up and down as I'm going down the road, just the very top, not an issue with anything working, just an annoying rattle basically. Because the plastic around the screw head basically cracked all the way around, is there an easy way to fix this?
Old 09-22-2008, 12:26 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Dash cracks
Can you use a washer to grab more of the plastic around the srew head?
Old 09-22-2008, 12:30 PM
Re: Dash cracks
Holy cow, sometimes the simplest things escape us. I'll have to check, I know there's a recessed area that the screw sits down in, I might be able to get a bigger washer down there.....
Old 09-23-2008, 12:05 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Dash cracks
If the piece that is broken off is in one or two pieces, you can use an epoxy to glue it all back together. I like Plastic Welder (stinks like he** but just about any 2-part epoxy will work. I'd use a clear formula so it isn't as noticeable if some happens to squeeze through during setting. Make sure it sets slow enough for you to put all the pieces in the right position before everything becomes permanent.
I also always apply it to the UNDERSIDE of the part (hidden from view). There you can slather it on thicker to help reinforce the part, then sand it flat so it can sit flush with the mating dash crossbrace. You can even epoxy a washer to the underside to give it more strength. When it's all done, it should look almost new. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-23-2008, 07:04 AM
bigcoconut bigcoconut is offline
Re: Dash cracks
"If the piece that is broken off is in one or two pieces, you can use an epoxy to glue it all back together. I like Plastic Welder (stinks like he** but just about any 2-part epoxy will work. I'd use a clear formula so it isn't as noticeable if some happens to squeeze through during setting. Make sure it sets slow enough for you to put all the pieces in the right position before everything becomes permanent."
DITTO - two part epoxy is your friend on these old truck dash pieces. You use it to cuild back up the area that is missing. Also, don't be afraid to "slather" it on. The screws were made to tap themselves into the plastic on the first assembly, they will do the same thing with the epoxy, after it hardens.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
