Old 09-21-2008, 07:08 AM
FordBoss88 FordBoss88 is offline
Interior / Cabin Lights Won't Turn Off
(2002 Dodge Grand Caravan EX)
Seems that this has happened to me before. Last night, I was working on my driver side door lock mechanism. I got things put back together (although the situation with the door lock mechanism remains unresolved), then this morning, I was pulling out and the interior lights will not go out. I have to use the dimmer switch to turn them off. How do I correct this?
Thank You
Old 09-21-2008, 08:50 AM
Bear Bear is offline
Re: Interior / Cabin Lights Won't Turn Off
I would check the on/off switch on the vertical pillar aft side of door (passenger side I believe). Push switch in by hand and see if the lights go out, if not take switch out and check wires, clean up all contcks and grounding spots and reinstall, see if that works.
