Old 09-20-2008, 06:08 AM
clampet clampet is offline
1995 Grand Prix with 3100 trans ?
1996 Olds ciera 3100 swap.
GA_googleFillSlot("Forums_ROS_300x250_noad"); var tcdacmd="sa=a;sz=3;ad";
Will a 1996 ciera 3100 bolt into a 1995 Achieve?
Will a 1996 ciera transmission bolt into a 1995 Grand Prix?
Any expert info on the 3100 V6 would be great.
Old 09-20-2008, 07:11 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1995 Grand Prix with 3100 trans ?
Externally, the transmissions are the same between the Ciera and the Grand Prix, but the Achieva most likely used the 4t40e, not the 4t60e in the other cars. One note, there are different final drive ratios in the 4t60e transmissions which could cause issues with speedometer calibration and such. A transmission ID tag or a run of the VIN # would tell you if the two cars have the same final drive ratio.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
