Old 09-20-2008, 12:53 AM
AngryBeargrrr AngryBeargrrr is offline
Exclamation help with subs!!
ok so i recently bought a new amp and hooked it up and the amp says the power is on but the subs are not working at all when i first hooked them up they worked for 20min then shut off and are not working again and i even hooked up another amp and see if that was the problem and its doing the same thing and i checked all the fuses and everything, so please help!!
Old 09-20-2008, 02:01 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: help with subs!!
how do you have the subs wired to the amp .... you probably have them set to too low of an impedace.
Old 09-21-2008, 09:24 AM
MotoAce51 MotoAce51 is offline
Wiring orientation would make a difference. 4 ohm subs have 4 posts that you can wire either series or parallel. You need to hook them up correctly or something could go wrong.
Also, subs throw off a lot of vibration, one of the terminals could have come loose either outside or inside the box. Check all connections.
Lastly check your power, ground, remote, and RCA cables. If there is a "cut" or something in them they will be working to your cars chassis instead of to the amp not supplying adequate power. Just run a jumper cable from your battery directly to the amp, that checks the power, do the same for the ground directly from the battery.
Also the size of the amp determines the size of the wore needed. If you have a 1200W amp you need a much larger wire. Too small of a wire draws too much power and will put the amp in protect. Hence why you will have it kick on although rarely. Use the same jumper cable type of checking...
Lastly, it may sound dumb but check your amp gor the gain settings and make sure they work, and check your sub output on the head unit work. It could be something simple...
