Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-19-2008, 05:26 PM
bluesboyst bluesboyst is offline
97 mustang cooling fan
HI,
Does anyone know why the electric cooling fan in my 97 mustang GT keeps running after the car is off?? I had to disconnect it after 20 minutes.
Thanks,
Steve
Old 09-19-2008, 06:28 PM
rhandwor rhandwor is offline
Re: 97 mustang cooling fan
I would check the fan relay it may be sticking.
Old 09-19-2008, 08:51 PM
HI,
Where is the fan relay located?
Thanks,
Steve
Old 09-20-2008, 08:35 AM
Look around the strut tower in the engine compartment. If you or a friend has a Ford or Mercury try swapping the relay before buying one. I've had them hang up more on Ford fuel pumps and Dodge ASD relays. As their made the same its a good possibility.
Old 10-31-2008, 08:48 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
Should be located in the power distro/fuse box in the engine compartment. The lid covering the box should be marked as to exact location of the cooling fan relay within the box. Yes, it does sound like it's sticking on.
Old 11-02-2008, 02:02 AM
Davescort97 Davescort97 is offline
Escort guy
The fan is supposed to run after shut off if the temp is beyond normal range. If it runs too long it could be the temperature sending unit for the PCM.
