Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 09-19-2008, 03:58 PM
airsense00 airsense00 is offline
Timing Belt
I heard if you don't replace the timing belt and it goes the engine will be ruined? Is this true? Also on average how much would it cost to get this done? I bought a used 2000 neon and I don't know if this has been replaced. Is it something the average joe can do?
Old 09-19-2008, 09:45 PM
shodid shodid is offline
Re: Timing Belt
Shodid...dont quote me on this...but i cant be dat far off...I know once a honda goes over 100k miles you need to change the timing belt because it will bend the valves if the belt brakes(I have one) so I'm quite sure it goes for any 4 cylinder!! my mom just bought an 02 sxt for $2800 (a steal) it has 117,000 runs good as hell...but im not taking any chances...im gonna change her water pump and timing belt on it!!!
Old 09-20-2008, 09:58 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Timing Belt
If the timing belt snaps then yes it can ruin bend the valves. This is because it is called an interference engine (which not all 4 cyl all). It would be wise to change the timing belt, water pump and idler pulley all at the same time.
You can do it by yourself with basic tools. The hardest part is getting the crank pulley off. But with the correct puller, it isn't that difficult at all.
Here is a great write up on how to do the timing belt. It is for a 1st gen neon, but its the same motor thats in the 2000 neon....
http://jball.neons.org/howto/timing_belt/howto.html
2003 Dodge SRT-4
Old 09-20-2008, 10:41 AM
discnik discnik is offline
Re: Timing Belt
A litttle caution to add. When re-installing the dampner bolt, be careful if you are using an impact wrench. The bolt will break if over torqued. Had one do that.
Old 09-20-2008, 11:19 AM
denisond3 denisond3 is offline
Re: Timing Belt
I would just not use an impact drive wrench to re-tighten any bolt. Especially one that is supposed to be torqued to a given figure.
I usually mount/install my own tires, but in the even I get tires installed by a store that uses an impact wrench, then after I get home I loosen them and retighten them again by hand. I dont think Im paranoid. Well maybe only a little.
I dont use an impact wrench to retighten the lug nuts on my motorhome either.
Old 07-28-2009, 09:58 PM
timd timd is offline
Re: Timing Belt
When I get tire work done at a store, I insist they NOT use an impact wrench. No warped rotors for me and no getting stranded by a flat cause I can't get the "monkey fighting" lug nuts off!
