Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-19-2008, 12:06 PM
Paultl80 Paultl80 is offline
Crankshaft Position Sensor How to Change? '92 V6
How do I change the Crankshaft Position on a Buick Century 1992 crankshaft position sensor?
Please forgive the following stupid questions:
Is it behind the dampener?
Is the dampener the same as the harmonic balance?
Can I change the Crankshaft sensor without remove the dampener?
It has a plastic shield around the sensor that I can't remove.
Any Ideas?
I've tried to remove the dampener, but I can't remove the main bolt.
The engine keeps turning, with the belt on or not.
I even tried the crazy thing where you brace a braker bar agianst the frame and kick the starter. But that only results in it being thrown under the car.
Help!
Old 09-27-2008, 10:20 AM
bruceallmighty bruceallmighty is offline
Re: Crankshaft Position Sensor How to Change? '92 V6
dude ur gonna have to wedge the flywheel with a big screwdriver , go under the car and u will see a plastic plate between the engine and tranny remove plate see gear,wedge it,need a good breaker bar to loosen that bolt, then pull off damper . u may need the special puller 4 this, rent or buy about twenty bucks. good luck
