Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-18-2008, 01:05 PM
billkater billkater is offline
Send a message via MSN to billkater Send a message via Yahoo to billkater
96 Ranger 'low ERG flow'
Check engine light came on the other day. Autozone read the code as 'low EGR flow'. Would this be a bad EGR valve? And if so. is it located right behind the PS pump, running from the exhaust to the valve to the air intake?
How hard is this to change? I know it is rusted and probably won't come loose without heat to it.
Thanks
Bill
Old 09-19-2008, 06:44 PM
rhandwor rhandwor is offline
Re: 96 Ranger 'low ERG flow'
You can clean the dpfe sensor connecting tubing. Also pull the egr valve and clean the inlet throughly. Use P-B Blaster and soak the threads good for a couple of days before trying to take it apart. The sensor goes bad more frequently. But the EGR inlet plugs up frequently.
