Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-18-2008, 12:29 PM
johnholl johnholl is offline
Question Is this caused by a faulty fuel cap?
This is my scan report:
Persons are indicating a faulty gas cap. Is there a quick manual check for the cap? I had the tank replaced last year...so we can rule the tank out.
1998 Chevy Malibu
3.1L engine
State ODB Check
MIL On P0440 Evap Emission Malfunction
Codes found 1
Monitors ok 7
Monitors inc. 1
Monitors N/A 3
Monitor Status
Misfire mon Ok
Fuel sys mon ok
Comp component Ok
Catalyst mon Inc
Heated catalyst Ok
Evap system mon Ok
Secondary air sys [not on this model year] N/A
Ac refrig mon N/A
O2 sense mon Ok
O2 sennse htr Ok
EGR sys mon ok
FREEZE DATA
* I believe the code was set when the engine was started. This is why RPM and MPH was recorded as zero
Trouble code P0440 Evap Emissions Control Malfunction
ABSLT TPS % 0.0
ENGINE SPEED RPM 0
CALC. LOAD 1.5
MAF GR\SEC 2.56
MAP kpa 36
COOLENT 196 degrees F
ST FTRM1 % .8
LT FTRM1 % -7.7
VEHICLE SPEED MPH 0
FUEL SYS 1 OPEN [is this the problem?]
FUEL SYS 2 N/A
Old 09-19-2008, 10:44 AM
73dartsport 73dartsport is offline
Re: Is this caused by a faulty fuel cap?
my 2000 malibu had the same code a while back and all it was the gas cap wasnt tightened after a fill up.
Old 10-05-2008, 12:30 PM
Searchlight Searchlight is offline
Try removing, inspecting, then re-tighten the gas cap. See if the light goes away. If not, replace it. They are only about $12-14 at Autozone.
Make sure you tighten to three clicks and be advised that it can take a while for the light to go back out. It won't necessarily go out immediately after the fix; I believe it can require up to three complete drive cycles.
Old 10-09-2008, 07:26 PM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Where you take the car for inspection some of them put like a pump on the gas cap and they tell you if it good or not
opcorn:
