Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-18-2008, 10:52 AM
Greymama Greymama is offline
Help with 94 Crown Vic LX
Can anyone out there tell me how to get the instrument cluster out of my 94 Crown Vic LX
Old 09-18-2008, 05:21 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Help with 94 Crown Vic LX
Maybe this will help. I can't find a good picture for you.
Disconnect battery ground cable.
Remove the instrument panel finish panel retaining screws and remove the instrument panel finish panel.
Remove the six lower instrument panel steering column cover retaining screws and remove the instrument panel steering column cover.
Remove screw fastening transmission control selector indicator bracket to the steering column tube. Detach the cable loop from the pin and cane shift lever. Remove the transmission control selector indicator bracket from the steering column tube .
Remove the four instrument cluster retaining screws.
Disconnect the instrument cluster connectors from the back plate and remove the instrument cluster assembly.
Remove eight screws from lens and mask assembly.
Remove the temperature/oil and fuel/voltage assemblies from instrument clusters.
Remove transmission control selector indicator from speedometer
Remove speedometer
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
