Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-18-2008, 09:13 AM
campermama campermama is offline
How can you tell if
a spark plug is cross threaded?
Old 09-18-2008, 01:41 PM
billkater billkater is offline
Send a message via MSN to billkater Send a message via Yahoo to billkater
Re: How can you tell if
If you take it out it should be able to be taken out with your fingers after getting it loose, Look at the the threads on the plug after it is out and see if they are 'messed up'. They should be clean and smooth, compare it to a new plug to see.
Old 09-19-2008, 05:39 AM
rhandwor rhandwor is offline
They sell rethreaders for this usually two different sizes with a space in the middle for your spark plug socket. Coat it with greese before using it I use them occasionally on plugs that are rusty. Use anti seeze on the new plug threads. If a plug doesn't start easily I would suggest using one. Here is a picture of one most parts stores carry them.
http://www.autopart.com/tools/toolsmain/tool/T_2360.htm
Old 09-21-2008, 11:28 AM
Thanks! The truck is almost apart, we decided to fix it the right way for piece of mind since my daughter is driving it.
Old 09-22-2008, 05:45 PM
Since I didn't look at it I can't say but I have used this tool and did 3 more plug changes without a problem. With new iridium 100,000 plugs it should last the life of a used vehicle. Stripped out plug holes are another problem.
