Axle question
I recently bought a 91 civic LX. The guy before me gave me all the receipts for the lifetime warranty parts. He had replaced front right axle, but the CV joint is already clicking again. He did this less than 2 years ago. I looked up the part at oreilly's and it says that it is for a 1.6L, but this has a 1.5L. Would there be a difference, or is there enough that it would have already caused this to go out? I don't want to have to buy another if I can just exchange this one for no charge. Thanks.
Re: Axle question
Wow, I just answered a question like this yesterday I think.
Yes, a 1.6 and a 1.5 axle are the same. The only time you need to worry about a different axle is: A) Different series engine, i.e., D16 and D15 can use the same axle, D15 and B18 won't interchange. B) Different type of transmission, i.e. Automatic or 5spd(unsure if there is a difference between 4spd and 5spd) There are a few exceptions to these rules, but 90%+ of the time, your good if you follow these guidelines.
Tony 91 Civic Sedan DX - Stock 287k Miles |
Re: Axle question
HF/STD axles have smaller hub-sides,
Automatic/4speed axles have smaller transmission sides. Anything else is interchangeable, nix the B/H/F/K series.
Honda-free since early 2009.Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win. |
Re: Axle question
By the way, the lifetime warranty doesn't apply after the vehicle is sold, and O*Reilly auto parts most likely will not honor the warranty, since you are not the original purchaser of the part. Take the guy you bought the car from with you, if you can get him to go.
They will require the old part up front for the warranty exchange if they honor it.
Re: Axle question
Thanks. I already talked to them about this, and they said they would still do it. They said they aren't supposed to, but would anyway for me. Nice to live in a small town,
Re: Axle question
I agree... I often get things like that too.
I just thought I'd warn you about it, since there was a chance that they wouldn't do it for you.
Re: Axle question
I brought in an axle once that I had tried to fudge the bearings back onto the mangled shaft.. When I went to set it down the entire outer joint fell off and metal shavings and grease went all over the counter!
The guy just shrugged and said "damn you did a number on that one" I was like "is it still ok to exchange?" his reply was "hell I dont care, looks like you deserve a medal for being able to do that kind of damage anyway" Life lesson, dont drive on bad axle for 3k miles...
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Re: Axle question
my previous civic, I drove about 50,000 with 2 clicking cv joints. lol. This one is getting bad fast though, so I figure I'd better change it sooner
Re: Axle question
I actually just replaced my axles... and they're both still clicking around tight corners if I'm on the gas... so they're lifetime for a reason :P
Cool thing is, I gave them back the set that I took off... the "new" ones are still on the car, and I got "new new" ones b/c I exchanged the "old" ones... if that makes sense to anyone. Then, when I'm done, I can take them back the ones that I have to take back off, and get my $40 core back. I won't worry about the core until I get a set that isn't borked tho.
Re: Axle question
You are correct on the size, but they will still fit, you just can't mix and match parts from one axle into another. The biggest issue with the axles are the transmission side, whether it will fit in the transmission or not. The majority of the outer joints are the same, thats why you are not required to swap spindles on most swaps(don't know anything about H/F/K, etc. swaps). This is the main reason I love my Hondas is how interchangeable they are.
Re: Axle question
But, I thought the HF and STD hubs used smaller hub ends, but the tranny ends were fine to swap anything... (unless you managed to get an Auto HF... that would fail.)
Re: Axle question
They are. An SI/dx axle will not fit into the hf/std hubs. Ive tried, they are way too big. Hence my DA front brakes :P
Re: Axle question
well, changed it out yesterday. I didn't think I was ever going to get the thing out. The combination of the guy before me thinking everything had to be tighter than a.....I'll stop there. But other than everything being tight, I couldn't get the axle out of that fork (not sure what's it's called). I ended up having to unbolt that and drop it out the bottom. It seems before on my other civic it just pulled right out when I took off everything from the end of the axle. It took a whopping 5 hours to do all this, I was extremely frustrated. 15 minutes to put it all back together. But everything's good now, so thanks everyone.
Re: Axle question
Next time, get an impact, a 17mm and a 32mm socket, and a 17mm wrench, and a pair of decent needle pliers.
It takes about 20 mins to change both of them... (imagine how pissed I was when I put the "new" axles in, and they were bad too... friggin clicking noise)
Re: Axle question
You going to use those needle pliers to pop the axle out of the transmission?
Tools needed: 1/2" breaker bar(or impact) 32mm Socket 3/8" ratchet 17mm socket and wrench Wire cutters(remove cotter pins, easier than needle pliers) Decent size pry bar(some axles take bigger bars than others) and whatever size socket you may need to place between the lower control arm and spindle to pop the lower ball joint out.
