Old 09-18-2008, 12:30 AM
anthrax718 anthrax718 is offline
1990 civic dx swap please read and help
i have a 90 civic sedan wit sohc i was thinkin bout doing a b series swap but i was told by a friend that the b series is too big and it wont fit with the ac compressor but i live in fl and i need ac so i decided to go with sohc vtec i wanna put a z6 head but what do i need to do as far as wiring goes.. what do i need to get??? how do i need to wire in the vtec?? right now i have a dual point fuel injection how do i connect the z6 intake manifold with the fuel injection please can someone help me here i am lost.. i need a guide..
Old 09-18-2008, 01:08 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 1990 civic dx swap please read and help
There are literally several dozens of write ups on this. Also your friend is a retard if he told you a b series wont fit. No the ac compressor will not bolt onto the block without an adapter bracket but they exist and are easily available.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-18-2008, 07:21 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
FAQs are made for a reason.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-19-2008, 10:48 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Why is everyone so concerned with keeping the D-series A/C compressor... just take your lines out, and run a compressor/lines from a 'teg.. the damn evaporator is in the same place, and the lines will run right to it.
Or, you could buy the adapter plate, and that's alot easier.
B-series won't fit..
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 09-19-2008, 11:26 PM
Tony's Avatar
TLD Member #1
What is A/C? Isn't that just rolling the windows down? Whats the engine have to do with that other than how fast you go to get more air in?
Tony
Old 09-20-2008, 12:25 AM
FrodoGT's Avatar
I had 2-40 ac for a loooong time. And currently do.
Current project:
Rio Red 91 hatch.
Old 09-20-2008, 08:52 PM
I use 2-70... the improved model.
It used to be 4-70.. but no power windows, and I lost the rear window cranks :P
