Old 09-17-2008, 11:13 PM
sherylglo sherylglo is offline
Clunking sound from front end
I have a 2001 Buick Lesabre Custom. When you go down a curb or hit a bump, there is a clunking sound coming from the front end. Hub assembly on the passenger's side replaced last year. Drive shaft and boot replaced a few months ago on the driver's side. Any ideas?
Old 09-18-2008, 08:03 PM
Rasp Rasp is offline
Re: Clunking sound from front end
It might be your ball joints are worn. That could be quite dangerous. I personally would recommend checking them out if even just to rule them out.
I once had a ball joint go on me and my tire ended up under the car as I was still moving. You can't steer when that happens and if you are going fast you could have a nasty collision.
It may not be that but I would for sure want to rule that out. You can check this yourself by jacking up the front of the car and try to wiggle the tire sideways and up and down. You should have little or no movement if your balljoints are ok.
Other causes might be your engine mounts are loose.
Old 09-20-2008, 07:24 AM
GringoPete's Avatar
GringoPete GringoPete is offline
I had the same exact problem with my 98 custom back in March. It turned out that my sway bar linkage needed to be replaced. Nothing major......$80 repair.
Old 09-20-2008, 09:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Don't forget to check the upper strut mount bushings!
Old 09-27-2008, 07:43 AM
Smith1000 Smith1000 is offline
I recently found that both front stabilizer links were rusted and broken on my wife's 97 Lesabre. They tend to rust and break. They run about $9 each and are fairly easy to replace. I otherwise could not tell that they were even in need of repair. I had jacked up the front to balance the tires and notice they were broken.
Old 09-29-2008, 08:57 PM
Thanks to everyone for your input. It turned out that both outer tie rod ends needed to be replaced and the stabilizer bars did too. Cost $375 at a garage to fix.
Old 09-29-2008, 08:58 PM
Also, the sway bar linkage on the driver's side needed to be replaced.
Old 09-30-2008, 08:11 AM
GringoPete's Avatar
Glad to be of help. It's good that you got it fixed right away as these are important parts in controlling the front end of your car and could result in an accident if ignoring such.
