Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-17-2008, 02:51 PM
chuckwest1 chuckwest1 is offline
Engine code P1443
My check engine light came on so I had it checked...the code reads:
Definition: EVAP canister purge valve mechanical fault or VMV fault condition
Explanation: ECM detected a fuel tank pressure change greater than a minus 7 inches of H@) in 30 seconds with purge less than 0.02 lbs per minute
Probable causes: 1. Failed EVAP pressure sensor
2. Blocked hose between purge valve and FTP sensor
3. EVAP purge valve stuck closed
Can someone translate all this for me?????
Old 09-17-2008, 03:03 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Engine code P1443
Code P1443 means that the evaporative emissions charcoal canister purge sensor did not detect any flow when the canister should have been purging into the engine intake system. The purging, controlled by the computer,takes place when certain conditions are met, such as engine speed and temperature.What the computer operates to effect this purging is a 12 volt solenoid valve, solenoid means it has a moving piston in it which covers/uncovers ports in the valve so that flow does/does not take place. The "gunk" coming out of the charcoal canister will sometimes cause this piston to stick, resulting in purging not taking place when it should, the sensor in the purge hose detects this and sets a fault/trouble code and also turns on the "Check Engine" light. The electrical windings in these valves seldom fail, but anything is possible. To locate and check this valve, first find the charcoal canister, it will be a round or rectangular black plastic "box" with several different size hoses attached to it. If in doubt that you've found it, look at the bottom, there will be a plastic foam filter there---make sure it is not plugged up---. Once you've located the canister, start following the hoses attached to it. One will go towards the engine, follow that one along until you find the control valve that it attaches to, that's the valve that's not operating. Several things you can do now, just buy a new one and hope it is not the wiring or computer that's at fault. If you want to check it and the wiring, first, with key off, disconnect the two wire connector from it. Use a 12 volt test lamp, turn the key to "run" and check for current at both wires in the connector, one sould have current. Next, connect the test lamp between the two wires in the connector, start the engine and let it warm up, then run the engine up to around 1500 RPM or so, the test light should come on, if it doesn't, then it is the wire that was "cold" when you checked for power at the connector. or the computer. If the light comes on, then it is the valve. Remove it from the vehicle and clean it with an aerosol can of carburetor cleaner,use the "straw" that comes with the can and spray the cleaner into both hose nipples on the valve, alternatly spraying and shaking the valve. When you no longer get brown "gunk" coming out of the valve, reinstall it in the vehicle, but leave, if possible, the hose from the cannister disconnected. Start the car and let it warm up, (if need be), now raise the RPMs to 1500 or so. valve should now open and a vacuum should be present at the open nipple. If so, the problem is cured. On some OBD II equipped vehicles, repairing some problems will cause the computer to turn off the check engine light if the fault is no longer detected, other vehicles require that the computer be interfaced with and the code purged with a scan tool.
