Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-15-2008, 05:37 PM
boomer64 boomer64 is offline
ABS/Speedometer
I have a 2000 Ranger and it went through a lot of water. Now when I start it the ABS and check engine lights come on but go off. When I hit the brake or use the turn signal the speedometer fluctuates to 0 and back. Any ideas on what the problem could be?
Old 09-15-2008, 08:43 PM
rhandwor rhandwor is offline
Re: ABS/Speedometer
I would check ground connections that got soaked. Use an ohm meter and check from cable to the frame. I would also clean connections to the wheels the water may have loosened some of them.
Also clean connections to the transmission speed sensor.
Old 09-15-2008, 08:47 PM
mrmikey mrmikey is offline
Re: ABS/Speedometer
The speed pickup is in the rear end. Check there for water in the plug or something loose in that area....Mike
Old 09-25-2008, 10:09 PM
DonSor DonSor is offline
Re: ABS/Speedometer
I had a similar problem. ABS light came on and I noticed that at low speeds, my speedometer was malfunctioning. Got my OEM and found out that ABS is interconnected with the speedometer. I replaced the sensor (located right above and fwd of the differential) Problem solved.
Old 12-24-2008, 05:07 PM
Engineer78 Engineer78 is offline
Re: ABS/Speedometer
There's a juction plug under the driver's seat, accessed from ouside. Moisture can get into the plug fron inside the cab, causes all sorts of problems.
Old 12-29-2008, 08:44 AM
manlystanley manlystanley is offline
Re: ABS/Speedometer
Follow Mike's advice. I had the speedometer going nuts and took out the differential pickup and cleaned it off. Works like champ for the past 3 years.
Best Regards,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
