Old 09-15-2008, 06:48 AM
jambes jambes is offline
Lumina Idling Problem
Just recently as yesterday i started up my 97 lumina 3.1 and found that my car was chugging and running at about 1k rpm while in park, i found that once i gave it some gas the chugging went away. But again as soon as i would slow below 10km/h it would lower to 1k rpm and start to chug and if i sit long enough it will stall. Sometimes while this is happening my throttle will stick and keep the rpms high enough for this problem to cease but then i accelerate without touching the gas. I've been told it could be anything from just getting a tune up or a clogged air filter anybody give me a couple solutions that i could try please
Old 09-15-2008, 09:16 AM
maxwedge maxwedge is offline
A990 racer
Re: Lumina Idling Problem
Welcome to AF, this can be many things, tough to tell what " chugging" constitutes here, if it is a misfire than a plug or wire could do it, I'd look for vacuum leaks to start with, I assume no check engine lite?
Old 09-15-2008, 10:24 AM
Ya the check engine light came on, the motor kind of stutters and will finally stall if i sit long enough. I'm assuming right now its the fuel pump from looking around at other posts so i'm going to get it checked for pressure, but i was wondering what would be making my throttle stick.
Old 09-15-2008, 02:52 PM
A990 racer
Get the code and post back, anything else is guess work.
Old 09-16-2008, 07:17 AM
Assuming you mean the code from a mechanic from the scanner?
Old 09-16-2008, 11:52 AM
Forgot to mention this problem only started after i replaced my alternator
Old 09-16-2008, 02:48 PM
A990 racer
Again, get it scanned for the code.
Old 09-18-2008, 07:19 AM
Went and got the error codes and got P0101, P0121, P1106, P1133, P1870. My mechanic told me i could remove a piece and spray it with carb cleaner and this might fix my idle problem, or am i for sure gonna have to replace parts?
Old 09-18-2008, 09:46 AM
airsense00 airsense00 is offline
I had a similar problem a while back but mine was more of a hesitation than chugging and that ended up being a throttle position sensor. Anyways here is some detailed info on those specific codes:
P0101
Mass Air Flow (MAF) Performance Problem
P0121
Throttle Position Sensor/Switch Performance Problem
P1106
Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
p1133
Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank
P1870
That is a transmission slip code I believe. This car is known to have problems with the TCC regulator valve. This can be mistaken for missing between 40-60 mph.
I would seriously check out the tps sensor and mass airflow sensor..
Old 09-18-2008, 10:46 AM
Ya from what i've looked at across the internet these are the two main problems
Old 09-18-2008, 12:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I would change the TPS first. A bad reading from it can cause the PCM to trip all the other codes as well due to vacuum and rpm readings not falling into spec with where the PCM thinks the throttle is.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-20-2008, 04:41 PM
Just wanted to thank everyone for their ideas it turned out to be a hose/vacuum seal on top of the tps that had lost its seal and was allowing too much oxygen in
