fiero wont run :(
put new spark plug wires, oil filter, alternator, and fuel filter and boot and had the throttle body redone and new gaskets. if i poor gas down the throttle body it runs for like 5 to 10 secs then it dies. What could it be? egr valve?
Re: fiero wont run :(
Sounds more like no fuel pressure. Has that been checked?
Jim |
Fuel pump??
It sounds like the fuel pump. The tank is under the car. Make sure dico the battery and then jack the car up, drain the tank and then take the tank out and change out the fuel pump. I had to do that on my car and now it is running like a champ. It is about $40 for a new pump.
if your gas tank has any rust in it, while you have the gas tank out take the time to clean and seal it. I didnt the first time I replaced my pump and I ended up getting stranded, towed, and having to replace the pump and filter again. There are several choices for sealer kits out there its worth the time and money.
