Old 09-14-2008, 07:46 PM
chrissbee77 chrissbee77 is offline
does this make sense
was looking on the net and found this link for changing brake fluid \
http://www.clubgp.com/cgi-asp/mods.asp?modid=7
what do you guys think. if it seems okay ill do it
Old 09-14-2008, 10:56 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: does this make sense
gravity bleeding. It works to some extent at removing the old brake fluid, but probably not very effective with trac control and abs pumps.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-15-2008, 09:56 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Unless there is moisture or contamination, there is no reason to change brake fluid for the most part. Some people do, and there are no ill effects, but it's not necessary. I love it when garages say you're due for a brake fluid flush!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-15-2008, 10:12 AM
tblake's Avatar
In God We Trust
what about when it starts looking dark greenish?
Old 09-15-2008, 10:57 AM
richtazz's Avatar
That would be contamination, normally from moisture or someone isn't opening the bleeders when changing brake pads, and is pushing the nasty fluid from the caliper pistons back up the system (not good on ABS vehicles).
