Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 09-14-2008, 06:15 PM
ALVARER ALVARER is offline
E-320 Alarm disable
i have a mercedes E-320 1996 with 150,000 miles.The alarm broke and i want to deactivate it to turn on the car
Old 03-21-2009, 09:08 PM
GTiRcr07 GTiRcr07 is offline
Re: E-320 Alarm disable
broke how, like the remote or the actual alarm module? if it was just the remote just lock and unlock the door with the key and the alarm is deactivated. if it was the module then you need the dealer to fix it
Wish it were a V-Dub
Old 03-24-2009, 09:55 AM
eclass eclass is offline
Yopu can not deactivate the alarm on that system. It is called DAS 2 and it will shut off the fuel injectors if it thinks there is a theft issue. You probably need a new key, if that is not it you will need to go to the dealer.
Old 06-28-2009, 05:04 PM
samabhi1261 samabhi1261 is offline
Did your problem solved? How you solved it?
Mercedes E63 2008 Mercedes Headlights
