Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-14-2008, 03:18 PM
cdiesel32 cdiesel32 is offline
help with code P1457
Hey I just got a 98 accord ex 4 cyl with a manual trans - 116k. About 2 days after I got it check engine light came on. I took it to the a Honda dealer and they pulled code P1457. told me it probably was the gas cap since i told them i just filled up the night before - however the part the tech said what it needed was the "canister and shut valve". I've read some other posts and got a whole list of stuff 1457 could be related to and 1456 is the gas cap. So my question is for $270 what are the chances the canister and shut valve will solve the problem? I kinda feel like they are shooting in the dark. They reset it and it has come on again. The car runs great, i just want the car to last for a good long time.
Also, the car shakes sometimes when driving above 60. most prevalent around 70 - 73. Is this just a tire balance issue?
And finally, dealer wants to replace front stabilizer bar (the whole thing) because it is worn and loose. is this necessary?
Thanks from a honda newb.
Old 09-15-2008, 12:45 PM
somick's Avatar
somick somick is offline
Re: help with code P1457
EVAP Emission Control System Leak Detected (Control Canister System)-05
That what I got for the code P1457.
Before paying dealer I would start with a new fuel cap. If you buy it from a dealer you will be sure that it is a right one. Drive with it for a while and the code may disappear.
For the sway bar I would just buy new bushings. I bough new set at Pep boys for 13 dollars.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 09-15-2008, 07:10 PM
I got a new gas cap today, and tightened it to about 15 clicks. 3 driving cycles so far and so far no luck. CEL is still illuminated. I still have my fingers crossed though. Also, i went to pepboys and they did not carry the stabilizer bushings. I'll probably buy them off the net. Thanks for the help.
Old 09-16-2008, 11:19 AM
somick's Avatar
I am not sure if they mean driving cycles or fill ups. Let us wait a little longer.
Good luck,
Sam
Old 09-20-2008, 08:04 PM
Took 4 days, but the CEL went off yesterday after about 200 miles (15 - 20 driving cycles). All thanks to a new gas cap. Thanks for the help.
