Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-13-2008, 10:56 PM
idontknow82 idontknow82 is offline
Awd on 2000 exploder xlt
Is this really running in 2wd? It feels like all wheels are being powered. I dont get thrown into the seat when I take off like a rwd would or a fwd for that matter. It has auto, 4hi and 4 lo on the selector. I got the front wheels to spin on wet pavement. My guess is that they are all being powered. Am I wrong here?
Old 09-14-2008, 09:04 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Awd on 2000 exploder xlt
Have you read through the owner's manual on the operation of this system? Specifically page 169? There's a lot of good information in the often ignored owner's manual.
In the event that you don't have the owner's manual, below is a blurb from the service manual:
"The Control-Trac transfer case uses an electromechanical clutch assembly to control torque to the front wheels. In the Auto mode, while at rest and under cruising conditions, the GEM activates the transfer case clutch at a minimum level. This allows for the slight difference between the front and rear driveshafts which occurs normally when negotiating a corner on dry pavement. Under any of the following conditions, the GEM will increase the torque sent through the clutch to the front wheels in order to prevent or control slip.
  • Slip is detected (by monitoring the front and rear OSS sensors in the transfer case)
  • Throttle position (by using the throttle position signal from the EEC)"
-Rod
