Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-13-2008, 10:39 PM
Rx7_Tuner Rx7_Tuner is offline
A 2.8 MFI to a 3.4?
Will a 3.8 directly swap into a 2.8 MFI? Will I have to buy a new harness?
Old 09-15-2008, 09:21 AM
MrPbody MrPbody is offline
AF -Advisor
Re: A 2.8 MFI to a 3.4?
No, 3.8 is NOT a direct swap.
The title of this thread says "3.4". Is that what you meant? 3.4 has the same block, externally. The iron heads are the same part number. For true performance potential to be realized, the plenum must be enlarged and fuel supply increased (more pressure, "bigger" injectors).
Jim
Old 02-18-2009, 08:31 PM
ottlaw2 ottlaw2 is offline
How do you go about opening the plenum. There are 3 parts to the intake, any particular 1 or all 3 must be reworked.
Know this is an old thread but I'm just now coming online here. bought an 87 GT 4 months and would llike to do a few improvements.
Old 02-23-2009, 02:00 AM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
For best results, the original Fiero plenum should be port matched to the 3.4L lower intake manifold. This is assuming you care to have the red plenum that says "Fiero" on it. If it's no difference to you, the 3.4 upper plenum can be used to avoid the port work.
Please note that the engine is question here is the 3400 SFI, a decendent of the 2.8 and later 3.1/3100 .
There was also a 3.4L DOHC engine produced by GM that appeared in the Grand Prix GTP, Lumina Z34, and Cutlas Supreme. It's not a direct swap!! The 4 overhead camshafts means the electronics are totally different from the 2.8, and the block is obviously different, though it does bolt up to the Fiero transmission.
FYI, if you like useless trivia, write this down:
Despite it's differences from the 2.8L, The 3.4 DOHC did appear in a Fiero, the 1990 Fiero GT prototype. Unfortunatly, it never made it to production.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
