Old 09-13-2008, 06:31 PM
lilsweets3138's Avatar
lilsweets3138 lilsweets3138 is offline
Send a message via Yahoo to lilsweets3138
Smoking under the hood
1997 LS 2.2L
Today I was messing around with my car..MAYBE going 20-45mph then brake (not to a complete stop) and go up one street then speed up and then brake again and etc. Anyways I was testing my new brakes but yeah I was going a little fast :-P Well I started smelling a burning smell and some white smoke was coming from under the hood. It wasen't like..Holy Crap! That's alot! It was more of..Hmm,why is it smoking like that??
I did look under the car,there is no oil leaking BUT it looks like there is some oil ON the actual car. Where you drain the oil OR the automatic transaxle fluid pan.
Any info would helpsome.
Thanks again,
Christina
www.cardomain.com/ride/2821880
Old 09-13-2008, 07:01 PM
inafogg inafogg is offline
Re: Smoking under the hood
sounds like you have a leak ''oil'' of some kind blowing back possibly getting on exhaust causing the smoke
Old 09-14-2008, 07:29 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
if you changed the oil recently, it likes to soak into the exhaust flex pipe, I knew mine liked to smoke from there.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 09-15-2008, 12:50 AM
Is it something to be concerned about and how can it be fixed? And no I haven't had an oil change.
Thanks again
Old 09-15-2008, 07:19 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
i read the title and thought "thats a hell of a place to go have a cigarette"
did it smoke just that once, a couple times, or is it doing it all the time now?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 09-15-2008, 03:05 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I'd look for the source of the oil on the underside of the car... you can bet there is (or was, until it burned off) oil on the exhaust too.
If you didn't wipe the oil off the new rotors (keeps them from rusting until installed), that could smoke a bit.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-26-2008, 04:30 PM
Well it ONLY seems to smoke when I drive at high speeds for along time..I'd say 20-30mins. Theres no oil on the exhaust and it's not the rotors. The only thing I see is a tiny bit of oil leaking from the vavle cover. I have a new valve cover gasket but I am not sure how to install it.
Old 09-26-2008, 10:54 PM
Lifted GMT-360!
Take some pictures if you can.
Valve cover gasket is easy. Just remove the intake, and take out the bolts holding down the valve cover. Clean the mating surfaces really well and re bolt everything back up with new gasket in place.
