Old 09-13-2008, 06:17 PM
BikerPaintballdude BikerPaintballdude is offline
Wireing??
I have 2 re se's (12") And a hifonics brutus 1606d amp. I need to know what all I need to wire everything together. I know i need 4 ga but thats about it. and do I need RCA cables?
I can hardly drive and I already have 3 different setups for each different car I MAY get. Planning ahead never hurt anyone, and some of yall should try it, it works.
Old 09-14-2008, 08:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Wireing??
you will need a 4 Ga or bigger power wire, the same size wire for a gnd wire. You will also need an RCA cable from your aftermarket deck along a single turnon wire (18 Ga should be enough). The last item is 12 Ga or better for speaker wires.
Old 09-15-2008, 07:47 AM
Re: Wireing??
Ok I just got all of that but now I need a line output converter because I chose not to get a new headunit due to money issues. So what would you sugest?
Old 09-15-2008, 05:49 PM
Audio Guy
Re: Wireing??
then that's just an additional piece of equipment you will need. The only other "problem" is where to get the turn on lead for the amp. All the other wiring is the same
Old 09-15-2008, 09:45 PM
Re: Wireing??
So I need a line output converter and a turn on lead just to get my rca cables to the amp?
Old 09-16-2008, 06:06 PM
Audio Guy
Re: Wireing??
the line output converter is just a way to be able to use the RCA inputs on the amp. The turn on lead you will need no matter what, to turn the amp on.
Old 09-16-2008, 09:21 PM
Re: Wireing??
oh ok. well what kind of a turn on lead do you suggest
Old 09-16-2008, 09:36 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Wireing??
dont get a cheap LOC there not worth it. Get something good like a JL cleansweep or a Fosgate 3sixty.1. They are all over 200$ but they are worth it. But even then you can just get a real headunit.
I would run nothing smaller guage then 2g, 1/0 is optimal. Save if you can't afford it. Buying stuff just to get by costs more in the end cause you are unhappy with it.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-17-2008, 07:53 AM
Re: Wireing??
So if I got a good head unit I wouldnt need a turn on lead or a line output converter?
Old 09-17-2008, 11:16 AM
pre98zetec's Avatar
Re: Wireing??
exactly, as long as the headunit has RCA outputs (which 99% do these days). they also have built in remote wires.
-Josh-
Old 09-17-2008, 05:16 PM
Audio Guy
Re: Wireing??
you will still need to RUN the wire from the deck to the amp ..................
Old 09-17-2008, 06:28 PM
Re: Wireing??
Yeah running the wires is not a problem I just dont want to have buy all that stuff. Ok I may save some more money and get a nice head unit
Old 09-18-2008, 07:28 AM
Re: Wireing??
And does the head unit have to have a bass pre amp or could I just use one of the other preamps on it?
Old 09-18-2008, 10:24 AM
pre98zetec's Avatar
Re: Wireing??
you will want a headunit with a dedicated sub preout
-Josh-
