Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-14-2003, 07:29 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
New To N2o
questions questions questions...
ok....i have a 90 hb civic and after getting some work done going to add nirtous (track only) and have questions:
1: why do the bottles need to be warmed?
2: what's an air cooled system
3: why do they need to be purged??
4: i want to get a 35lb bottle so that i'll have more and have to fill up less...is this a good idea or it doesn't matter either way....and how many 50-75 shots can i get out of that size bottle??
ur help is appreciated
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-14-2003, 01:12 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Re: New To N2o
1. Keeps the pressure up and gives you a steady hard shot. If you have low bottle pressure the solenoids have a hard time pulling the nitrous from the bottle and your nitrous will sort of "sputter".
2. Not n20 related I don't think...Don't know
3. After you make a nitrous run, you have left over nitrous in the lines running from the bottle to the engine. Purging drags this extra N20 out of the lines and disposes of it into the atmosphere to that your lines are "clean" and ready for the nest nitrous run.
4. 35lbs!?!? That's insanely huge. The most I've ever seen for normal street use is a 15lb bottle. And even that's pretty big for a small shot like that. I would say go with a 10lb and call it a day. You'll get 15 or so nitrous quarters from a 10lb bottle jetted for a 50-75 shot.
There's no replacement for displacement...No, not even a turbo.
Old 03-22-2003, 06:41 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Cool
A 35 lb bottle would cost you $122.5 to fill it up. Thats not a good idea, plus it adds more weight to the car. IU have a 10lb bottle and last night I went to the track and made 5 passes spraying a 60 shot and i have about 7lbs of n2o still in the tank. And yes if you get a N20 kit get a bottle heater, it is a must b/c when you spray the N20 is in movement and it seems to get colder and the pressure drops some every time you use it. Good luck with the N20.
