Old 09-12-2008, 06:18 PM
oldmanlat oldmanlat is offline
ping
Hi.
I have an 02 Windstar 3.8. I'm getting a ping sound, or clatter, (just like with an older car when the timing was too far advanced) especially when hot, and under slow acceleration. I replaced the fuel filter, spark plugs, air filter, cleaned the mass air flow sensor, and tried premium gas. No change. I've always used regular gas with no problem.
Any ideas?
Thanks.
Oldmanlat
Old 09-12-2008, 06:51 PM
garync1 garync1 is offline
Re: ping
I would call the dealer and see what they would charge for a PCM timing upgrade.. It cost me 74.00 in Fayetteville NC.. Which was a good deal to me..Had the same issue also on my freestar. Under warranty so that was free.
Old 09-12-2008, 08:37 PM
hoofarted hoofarted is offline
Re: ping
I had the exact same thing happen on my 02. Check your IMRC linkage bushings.
Old 09-13-2008, 09:26 AM
wiswind wiswind is offline
Re: ping
FORD has a TSB about the IMRC linkage as a cause for pinging.
They say to verify that the actuator is connected to the shafts.
What happens is that the nylon clips break or fall off......and the shaft that has the "butterflies" in the lower intake manifold no longer turns.
This can happen on 1 side and not the other....and this results in the PCM not being able to ballance the motor out.
The other thing that can cause this is a vaccum leak.....not serious enough to set a failure code....but enough to lean out the motor enough to ping.
There is another TSB to fix this.....a bit more involved......
A great site for this is here
http://leckemby.net/windstar/windstar01.html
Another cause can be carbon build up inside the cylinders from excessive oil being drawn in.
FORD's solution to this is to reprogram the PCM with a program that slightly retards the timing.
For a fuel injector cleaning.....the most effective one that I have found out of MANY that I have tried is Berryman's B-12 Chemtool.....in the metal can.
You can find this at many auto part stores, like AutoZone and Advance Auto Parts.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-14-2008, 04:26 PM
Re: ping
Thanks for the info. I did have broken plastic bushings on the IMRC rods. I replaced them, then I had to replace the plugs. They got fouled badly driving it without the IMRC. (what a pain replacing the rear 3) I'll investigate the PCM upgrade, and try the Berryman's FI cleaner.
Thanks again. I'll keep you posted.
Regards,
Oldmanlat
