Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-12-2008, 05:20 PM
CrudesPeyote's Avatar
CrudesPeyote CrudesPeyote is offline
1995 Saturn SL2 Gas Pedal Problem
I just bought a 1995 Saturn SL2 is excellent condition. The only problem I seem to have, is when applying pressure to the gas pedal to get her going, the pedal seems to stick. It happens every time, but once past that initial sticking, the pedal is nice a free.
Any ideas on the cause or a way to fix it?
I don't want to "jump" into someone's bumper by applying too much pressure!
Thanks!!!
Old 09-12-2008, 10:19 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 1995 Saturn SL2 Gas Pedal Problem
Clean the throttle body. It is very common for a lot of crud to build up behind the throttle plate and cause the very symptom you are describing. Its a very cheap first step and likely needs it anyways.
Old 09-13-2008, 12:28 AM
Cat Fuzz Cat Fuzz is offline
+1 ^^
Old 09-13-2008, 10:44 AM
RC1488 RC1488 is offline
+1. While your in the TB, take it off and clean the IAC passages and vacume passages on top of the TB.
Also replace your ECTS (one with the two wire connector) as im sure you have not done that yet. New ones are brass and last the lifetime of the car.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
