Old 09-12-2008, 03:15 PM
gunslinger1_1 gunslinger1_1 is offline
ABS problem
Hi Gang,
My 99 blazer has an intermitten ABS fault. It usually happens when I'm going around a sharp corner. The ABS light will come on. As soon as I turn the car off, the light goes out. It happens when I turn right or left.
Also, off and on, if I'm braking when I make a sharp turn, it will act like the ABS is engaging, but I lose all stopping power.
Any thoughts? I'm assuming it's a short, but I don't know where to even start looking.
Bob
Old 09-12-2008, 05:26 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: ABS problem
Originally Posted by gunslinger1_1
Hi Gang,
Bob
Your assumption is most likly correct. If you know which side is causing a short, take a close look at the connection from the hub(two wires) and follow it up and around to the actual connection. Usually its rubbing somewhere on and has rubbed right through and causes an intermitent short if the wheel is turned, or the suspension is moving.
