Old 09-12-2008, 10:39 AM
luchjeg6 luchjeg6 is offline
Headlights surrounding
Can you please explain to me how to do a good lights surrounding?
Old 09-12-2008, 11:46 AM
stevenoble's Avatar
Re: Headlights surrounding
On which model/car? Give us a little more information......
Steve Noble
Old 09-12-2008, 11:51 AM
It was just a question in general, but for example now I'm working on a protar mercedes benz s600
Old 09-12-2008, 12:02 PM
ZoomZoomMX-5's Avatar
We seriously need more information; your question is far too vague.
What type of surround? Inside or outside? Color? Finish?
Look at pictures of a real car and use hobby paints to simulate the colors. That's all I can say with such little information.
My Fotki Album
Old 09-12-2008, 12:11 PM
the surround of the headlights which I think has to be black.
Old 09-12-2008, 01:16 PM
Black is best done w/a black Sharpie permanent marker; chisel or pointed (cone shaped) tip. Fast and easy.
My Fotki Album
Old 09-13-2008, 04:08 AM
Murray Kish Murray Kish is offline
Getting Old...
Try this. Take the headlight lens (before it's installed) and run a black sharpie around the edge. You can angle the pen is just a way to get most of the ink on the side of the piece, with only a very thin line on the top of the plastic (the front of the lens). It's delicate work, because you'll have a hard time holding the lens and getting all the way around the piece without mucking it up with your fingers. If you can do it in two stages (one half, then the other), that seems to work best for me.
Install with clear glue of some sort (I actually use Future floor polish...) and you should be good.
I've had mixed results with this. The end result depends a bit on how well the lens itself actually fits to the body. The better the fit, the better the result.
Good luck!!
Murray
