Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 09-12-2008, 05:13 AM
eronius_monk eronius_monk is offline
97 CRV engine cuts out? help!!!
I am having a problem with my CRV. I will be driving down the highway when all the sudden i have no acceleration, i put the pedal to the floor and nothing happens. The rest of the car is acting perfectly normal. I pull over, turn the car off and back on and everything is fine and i'm on my way. Anybody have any ideas before i spend a fortune to figure this one out. Thanks in advance
Old 03-18-2009, 03:05 PM
eforce eforce is offline
Re: 97 CRV engine cuts out? help!!!
Your car need tune up! The power seizure problem mostly coming from the power drop in the spark plug cable and contact point in the rotor. Try to open the cap & rotor, sand both contact, put the cover back and test drive, this should give you time to drive around more... but get your complete tune up soon.
Old 07-07-2009, 07:18 PM
jacobbesanceney jacobbesanceney is offline
mine did that. driving down road, engine would stop running, radio would turn off, and all lights would turn on in the instrument cluster as if you were about to start your car. Sound like what's going on in ur truck? If so, it's an ignition problem. It's so common that honda dealerships keep this part in stock. Easy to change out as well. It's the plastic part that is on the back of the ignition switch with wires attached to it at the end.
