Old 09-12-2008, 12:50 AM
odie241 odie241 is offline
No Power At The OBD-II Connector
Hey everyone,I have no power to the obd-II connector on a 2000 cavalier,i checked all of the fuses,its a 4 pin connector,and i tested the leads with a power probe,ground on all 3,except one,and it niether has power or ground,its a orange wire,am i missing a fuse somewhere?i checked the fuses in the driverside dash,and under the hood.scanner works on other veihicles,just not this one,check engine light is on,not running rough or anything,probably a 02 sensor,but i want to be sure,
Old 10-23-2008, 08:45 AM
roger0520 roger0520 is offline
Re: No Power At The OBD-II Connector
there is a diagnostic way to figure that out if the pcm or obd2 fuse is okay then it is either the wiring to it or the pcm itself i would get a book for the wiring diagram and go from there
Old 10-23-2008, 09:14 AM
brcidd's Avatar
brcidd brcidd is offline
The orange wire is on circuit "40" - it should be battery hot-- uses the "CIG" fuse in your IP fuse block inside car. Does your cigarette lighter work?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-23-2008, 09:19 AM
Indy Tech Indy Tech is offline
Your OBD II connector is a 16 pin connector under your drivers side dash near your legs if you have no power check your fuse left side of Dash if i remember it was the dome light fuse ?
indy shop owner/tech
Old 10-23-2008, 05:02 PM
Jacfourteen Jacfourteen is offline
I have the same exact prob in my 97 z and my cig lighter has stopped working also. I checked the fuse in the dash and it tested good, and I checked and there is power to the hot side of the fuse. anything else that I should check or just start tracing wires. At least I now know that these issues are related, I never would have guessed that. Thanks in advance!
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 10-27-2008, 12:38 AM
ok thanks for all of the info,i will check into that on tuesday,i will let you know what i find out,thanks again,Odie
